I am using EPM900 to debug a board with lpc932. I have to make a net RS485 multiprocessor with uart in mode 3, 9 bit . The problem is the seguent: if I run the firmware on the lpc932, the system work, while if run the emulator, when the code clear the pin of SN76175 for the reception, the emulator start again from the main(). I have disabled the break detect of the serial but the problem rest. Does anyone can help me to resolve the question. Best regard Antonello
