Hello, Keil uVision generates as output HEX file. Do you know how I can generate BIN file? Unfortunately hex2bin program doesn't work. Message error "Invalid record type in HEX record 1" does occured.
Best regards, Piotr Blaszczyk
The RealView compiler uses some new HEX record types that might be not known to the tool that you are using.
Take a look here: en.wikipedia.org/.../Intel_HEX
Use the FromElf.exe instead of creating a HEX file and converting it to bin.
FromElf.exe --bin --output FileName.bin FileName.afx
You can also just edit the Hex file fixing the 1 or 2 lines that are not recognized.
