jump to a location
can i jump from a bootloader designed by me to an application program by changing the ProgramCounter .. i have an address location in a variable ..
mov pc, addr .. is this possible or any other options
... there is no return from application to bootloader program..
plz help me
  • From the ARM Assembler Guide:
    You can also load the program counter directly using data operation instructions.
  • plz help me .. how can i do that ..
    when i used the move function it returned error
    i am using GNU compiler
    asm("MOV PC,=ADDR"); returns error as shifting register expected
    no error when asm("MOV PC,0x8000");
    how can i jump to code block whose address is in global variable
    i have also tried LDR R0 and BX r0 as in startup.s
  • To jump to a function whose address is in a global var, you don't need to go low-level. Declare your var as a function pointer:
        // declare pmain var as a function pointer to a int(void) function
        int (*pmain)(void);
        // do whatever you do, and load the target address in pmain
        pmain = (int (*)(void)) 0x40000000; // cast it to the func ptr type
        // now call the code pointed by pmain.
        pmain();
        // pmain will never return ...
    This produces code like:
    0x00000250  E3A00101  MOV       R0,#0x40000000
    0x00000254  E1A0E00F  MOV       R14,PC
    0x00000258  E12FFF10  BX        R0
    That is only one extra instruction from doing MOV PC, R0, generally irrelevant in a ARM processor.
    Another point in your post is to optimize for a function that never returns. The RVCT has the function qualifier __declspec(noreturn) to tell the compiler that it is OK to remove the function return code from the target function.
