I plan to use the TcpNet from the RL-ARM. Which ethernet controllers are supported by TcpNet ? Are the device drivers available in source code ? Thanks Mario
We have on ARTX166 a CS8900 driver. It should be realatively easy to port this driver.
Do you have an Eval Board that is using a CS8900?
We plan to design a board with the CS8900A, because it is cheaper then the LAN91C111. Is it possible to get the driver of the ARTX166 when we buy the RL-ARM ?
Yes we can provide you the source code of the CS8900.
Can you provide a demo program with CS8900A driver and ARTX?
