I keep getting a data abort on the same line of code. When I trace back to which line it is, its inside the os_get_first function. I don't have the source code for the ARTX, so I can't figure out what's happening. Does anyone know what this function does?
It might be that you address an non-existing memory location. See: http://www.keil.com/support/docs/3080.htm If you cannot figure it out, send a test case to support.intl@keil.com
