problem in running the ADC program on MCB 2140 board
Im facing a problem in running the program for the ADC in lpc 2148 on board MCB 2140,With the use of simulator of KEIL the code is working well and even showing the expected result on the serial window..But when it is tested on the hardware i dont get any result in the ADDR (digital data).I have tested the i/p of the analog pin AIN0 also which is been suppied to the LPC rightly..What else can be the problem..plzz can i get some help...
