Compilation Error for an example 'Hello World' program for DS80C400
I tried to compile a 'Hello World' program from http://www.keil.com/download/docs/305.asp using Keil.
I get the following error
assembling startup400.a51...
startup400.a51(185): error A84: OPERATOR REQUIRES A CODE/ECODE ADDRESS
Target not created
Line 185 corresponds to the below instruction
ljmp far sanity_check ; Sanity check: Make sure 24 bit mode is on
However if i remove the directive far then the code compiles.
I'm using C Compiler: C51.Exe V8.01
Assembler: AX51.Exe V3.01
Linker/Locator: LX51.Exe V4.03
I havent changed any options and verified that extended assembler and linker options have been ticked..
Any ideas on how to resolve this?? I'm kinda new to keil.
