Hi , I got a basic doubt.When we compile and build our programs in keil simulator we are getting a line in the output window
Program Size: data=102 xdata=8184 const=45 code=7058
Hi, This line brings out the total size of your code and variables used. data : represents the total size consumed in the internal data memory. variables declared with the 'data' memory specifier are stored here. xdata : represents the total size of local and global variables stored in the XRAM. const: represents the constants stored in the code memory (in most cases) code: represents your code size stored in the code memory.
The OP stated ARM, but omitted to state which compiler; the reply relates to C51.
Hi A.W.Neil, The doubt is regarding ARM (Keil Uvision3)
