10 bit
Hi
I want use 10bit ADC in my project.
What are the popular 10bit ADC
thank you
  • What supply voltage?
    What input type - differential? single-ended?
    What input range?
    What sample rate / conversion speed?
    What sort of interface - I2C? SPI? Parallel?
    etc, etc...
    Remember: 10 bits means that each step in the digital output is 1/1024 of the full scale; ie, about 0.1%
    For this to be of any use, all the other errors in the rest of your circuit - noise, tolerances, etc - need to be well below 0.1%
    Precision analogue design is not trivial!
  • LPC2138 has a 10-bit ADC on-chip.
    See http://www.keil.com/dd - Parameteric Search
  • "I want use 10bit ADC in my project.I want use 10bit ADC in my project."
    So this must be purely a learning exercise?
    In that case, you should start by considering what 10-bit ADCs you can actually obtain easily and within your budget.
    Otherwise, this is entirely the wrong way to proceed!
    The first thing to do is to define your Requirements:
    * What do you need to measure?
    * What are its parameters?
    * What are your other design constraints?
    Having established the requirements, only then should you start thinking about a solution!
    You are starting with a solution (10-bit ADC) and working backwards to a question!
