Well, scanf now works fine. I can read signed int, hex and float. :-) But every received sign is echoed by scanf.
while(1) { printf("Enter your personal secret Hex-key!\n"); if (scanf("%X",&A)) break; scanf("%*"); //Clearing scanf input stream }
"But every received sign is echoed by scanf" No it isn't - it's echoed by getchar: http://www.keil.com/support/man/docs/c51/c51_getchar.htm As suggested in your previous post, you should really read the stuff into your own buffer, and then use sscanf on that! http://www.keil.com/forum/docs/thread7600.asp
Hello, Did you see ungetchar()/getchar()? I hope to help you this. Best Regards...
"Did you see ungetchar()/getchar()? I hope to help you this." It's getchar that's causing the "problem"!
Now i have this solution, works pretty well.
//*********************************************************************** //* putchar & _getkey for the ADuC7026 //* 24.04.2006 : Echo cancellation //*********************************************************************** #include <aduc7026.h> #define CR 0x0D #pragma thumb static int Echo_flag; //*********************************************************************** int putchar(int ch) /* Write character to Serial Port */ { if (!Echo_flag) { if (ch == '\n') //additional CR { while(!(COMSTA0 & 0x020)){} COMTX = CR; } while(!(COMSTA0 & 0x020)){} COMTX = ch; } Echo_flag = 0; //Echo on for next call of putchar return (ch); } //*********************************************************************** int _getkey (void) { while(!(COMSTA0 & 0x01)){} //waits until a sign appears in COMRX Echo_flag = 1; //Echo off for next call of putchar return (COMRX); } //***********************************************************************
