I set up my LPC932 to use the independant baud rate generator at 9600,using the internal RC oscillator. During my project I changed to an external oscillator (12MHz). Do I have to reconfigure the BRGR registers to get the same baud rate with the new oscillator?
Why do you have to keep starting new threads for every little step of this?
http://www.keil.com/forum/docs/thread8956.asp http://www.keil.com/forum/docs/thread8954.asp
Anyhow, the Datasheet says,
"The independent Baud Rate Generator uses OSCCLK."
So, if OSCCLK has changed, the answer should be obvious...
