Hi Guys,
I had a small doubt on how to enable download option in Keil. Please reply how to enable and how to download a code using Keil.
Did i can use serial port for downloading program?...
Although it's titled "Flash Programming", the following also applies to other types of downloading: http://www.keil.com/support/man/docs/uv3/uv3_flash_programming.htm
Note that the thing that does the actual downloading will be a 3rd-party utility, and so will have its own documentation
See also:
http://www.keil.com/forum/docs/thread8931.asp
Sir... What is ULINK JTAG Adapter. where i can buy that?
http://www.keil.com/ulink/
You may find that some chip vendors can offer a special deal on this - particularly if ordered from them and/or in association with one of their development kits, etc... Check with your chip distributor...
"You may find that some chip vendors can offer a special deal..."
Example: mcu.st.com/.../modules.php
