Checking User Stack during runtime
i'd like to know how much space I need in the Userstack Area.
I'd cleard the UserStack-Section in start_v2.a66.
In my 'main.c' I'd like to have a function which shows me the Userstack. Therefore I have to know where the UserStack is located.
So how could I get access to ?C_USRSTKBOT & ?C_USRSTKTOP in 'main.c'? (I could look in the Memory Map & type in the numbers by hand, okay. But automaticaly it would be nice)
/Koarl
  • Thanks for the hint with the app.-note.
    Unfortunately, it only works with sections in NCONST or NCODE!
    If i'd like to get access to a section in NDATA (like ?C_USERSTACK) I get an Linker-Error (ERR 127: Unresolved external symbol)
    /Koarl
  • Why don't you simply make stack top an bottom public in START_V2.a66:
    PUBLIC  stack_top
    PUBLIC  stack_bottom
    ?C_USERSTACK    SECTION DATA PUBLIC 'SDATA'
    ?C_USRSTKBOT:
    stack_bottom:
                    DS      USTSZ    ; Size of User Stack
    ?C_USERSTKTOP:
    stack_top:
    ?C_USERSTACK    ENDS
    And declare extern where you use them:
    extern unsigned int stack_top;
    extern unsigned int stack_bottom;
    Sauli
  • Hello Sauli,
    thank you for the tip it works!
    I'm not so familar with the assembler.
    Only for better understanding the hole thing, do you know why I cant get acces to the '?C_USRSTKBOT' Label? (which is in the original start_V2.a66 'public')
    /Koarl
  • I guess it has something to do with the question mark in the label. You cannot have a question mark in any names in C code. There is a hint somewhere in the Keil application notes that you could use underscore in C code to reference a name containing a question mark, but trying to use _C_USRSTKBOT to access ?C_USRSTKBOT does not work. I am sure that Keil people could explain this if they wanted.
    Sauli
