I am new to ARM and am using Keil micro vision v3 and was tryin to build the example for RTX kernel.
While doing so i encountered the following error
RTX_ex1.axf : error :L6938E : Invalid value for --ro-base.
Can anyone tell me why this is happening and how do i get rid of this error.
Help will be deeply appreciated
Thanks Meenakshi
I changed the linker R/O base to 0x0000. Now this error is not coming. However when i try to build the target again i get a whole lot of errors relating to the OS tasks.. some of them are as below
RTX_ex1.axf: Error: L6218E: Undefined symbol os_dly_wait (referred from rtx_ex1.o).
RTX_ex1.axf: Error: L6218E: Undefined symbol _init_box (referred from rtx_config.o).
RTX_ex1.axf: Error: L6218E: Undefined symbol tstclrb (referred from rtx_config.o).
RTX_ex1.axf: Error: L6218E: Undefined symbol SWI_Handler (referred from startup.o).
Please tell me why this is happening. why is the linker not able to access the OS tasks
Regards Meenakshi
have you included in your project the RTL.h library? What kind of version of OS are you using?
I have included the rtl.h file...
The project is a demo example availiabel with the evaluation kit. It uses the RTX kernel availiable with uV3. How do i find the version of the OS.
SHould the version affect the execution especially when i am using just the basic os tasks.
You can find the version opening the release note RTL_Release_Note under \Keil\ARM\Hlp. You have also select RTX Kernel in the window "operating systems" under Project - options - target in the MDK keil.
In any case, tell me what's the name of the example that you use that I try to debug for you.
Regards.
hai Meenakshi,
just now i have compile that program. it is compiled sucessfully with out errors. here i am using uvisin3.03a full version. and my sugession is just have a look on startup code and options for target.
regards =-raj=-
hai, i want to know on which microcontroller u r working.
regards -=raj=-
