Hi folks
I'm using UV3 (V3.33) and if I collapse and uncollapse few block from my C-code the UV3 crashs.
This behaviour happens on different PCs up to P-4 3GHz.
Is there a bugfix in the queue?
hopeful - Günter
We are not aware of such an issue, but we would like to check this. Can you send more information to support.intl@keil.com?
OK, I use example \Keil\ARM\Examples\Measure.
Opening measure.c from 22. mai 2004 16:57:58 13.013 bytes
place cursor at line 259 (last } from main() press F3 to collapse current block. line 164 to 260 is hidden, ok. place cursor at the 3 dots in the main() line 163 pressing ALT+F3 (stop collapse) crash the UV3
May be its a problem from the keyboard interface in UV3. I don't use the mouse for writing programs ...
Playing a little bit with F3 and Alt+F3 cause in a lot of c-files quickly the crash. Blinky, WHET, Measure etc
OK, it seems that you have assigned some shortcut keys to the Edit - Outline commands. Can I get this assignment.
Also we would like to send you a slightly new UV3.EXE to see if the problem is already fixed. How can we reach you?
