I'm making an application with an at91SAM7S128 uC and use the USB interface. As starting point I use the demo application. For my application it is required to send two bytes to the PC. I try to change the report, but it when I try the device is not even found by windows.
When I try to double the data I can receive from the PC (as show in the source below) is works fine. Have anyone an idée how I have to modify this report descriptor so I can send two bytes? Or must I change more on the demo program to get it working?
/* HID Report Descriptor */ const BYTE HID_ReportDescriptor[] = { HID_UsagePageVendor(0x00), HID_Usage(0x01), HID_Collection(HID_Application), HID_UsagePage(HID_USAGE_PAGE_BUTTON), HID_UsageMin(1), HID_UsageMax(4), HID_LogicalMin(0), HID_LogicalMax(1), HID_ReportCount(4), HID_ReportSize(1), HID_Input(HID_Data | HID_Variable | HID_Absolute), HID_ReportCount(1), HID_ReportSize(4), HID_Input(HID_Constant), HID_UsagePage(HID_USAGE_PAGE_LED), HID_Usage(HID_USAGE_LED_GENERIC_INDICATOR), HID_LogicalMin(0), HID_LogicalMax(1), HID_ReportCount(8), HID_ReportSize(2),// <- this work HID_Output(HID_Data | HID_Variable | HID_Absolute), HID_EndCollection, };
The problem is solved. I had looked only at the line's I used, but it that's not enough. When You also whant to change the size, keep in mind that the demo source don't send a byte, but only the last 4 bits.
This lines gives the problem. (HID_Constant)
If you change the descriptor to this:
const BYTE HID_ReportDescriptor[] = { HID_UsagePageVendor(0x00), HID_Usage(0x01), HID_Collection(HID_Application), HID_UsagePage(HID_USAGE_PAGE_BUTTON), HID_UsageMin(1), HID_UsageMax(254), HID_LogicalMin(0), HID_LogicalMax(1), HID_ReportCount(8),// <- 8 bits HID_ReportSize(2),// <- 2 x TX HID_Input(HID_Data | HID_Variable | HID_Absolute), HID_UsagePage(HID_USAGE_PAGE_LED), HID_Usage(HID_USAGE_LED_GENERIC_INDICATOR), HID_LogicalMin(0), HID_LogicalMax(1), HID_ReportCount(8), HID_ReportSize(2),// <- 2 x RX HID_Output(HID_Data | HID_Variable | HID_Absolute), HID_EndCollection, };
Sending with more or les data is easier to adjust, and it seems to work fine. For me this is the solution, I hope it will help you when you also have problems.
