I want to get result in graphical , i used keil for simulation but i need some graphical result of the same simulation which i can present in a paper or in thesis
What exactly do you want in "graphical" format? uVision-3 has a Logic Analyser display in the debugger: http://www.keil.com/support/man/docs/uv3/uv3_cm_la.htm Or do you just want screen shots? Or are you developing some sort of data acquisition system, and want to display the acquired data?
Thanks for the reply I m using the keil uvision 2 , i made programe using nrf24E1 transciver for sending and receiving the data i want the simulation in grahical form in order to present my result in paper form . would you like to help me in this thanks
" i want the simulation in grahical form" Simulation of what? What "graphical form" do you want - flowchart? dataflow diagram? some UML diagram?
Thanks sir I made programme in c for transfer data between 2 nrf24E1 boards in these board we have transciver with builtin 8051. As like performance anylyzer , i need some out of result of my programme in grahical form.As usually we get in MATLAB after simulation , when i run prog i get the result on serial window but this can not be published in paper or thesis so i need the result in grahical form which i can print also. If sitll not clear please reply i will be thankful to you thanks
on the keyboard [Control][Print Screen] [Alt][Print Screen] [Shift][Print Screen] save the screen or cuurent window. Paste it in to "paint" or you document.
