In the project I'm working on, I'm loading two separate applications to the AT91SAM256 Flash, the first one is the Bootloader and the 2nd is the Main Application.
For the Bootloader, I have finished the receiving bin file, decripting it to hex buffer and writing the hex buffer to flash. The next step is to jump to the main application.
I write the code like this(not working):
(defined and declared at the beginning) typedef void (*tFuncP)();
(In Main() function...) tFuncP pFunction;
pFunction = (tFuncP)(APPLICATION_ADDRESS); (*pFunction)();
Is there any thing wrong with the jump_to_main code?
The compiler i use is Keil uVision 3.23.
Hope somebody can help me...
Thanks in advance!
