I have declared variable as,
const float a = 5.5;
In my project after compilation the program size is,
data = 17.0 xdata = 4421 code = 38520
I am using 8031 with 64KB external EPROM and 8KB external RAM.
The settings in the target options is i specified only the memory range.
But when i run program i found the above is same for the first time(that is calculation is done with that declared constant value. This calculation is done everytime the corresonding function is called).
But i found that the constant value is same for the first time calculation but on the second time it is changing.
What is the problem i couldnt identify?
Please help me regrading this.
Do i need to any setting?
