hi, here we are using MCBSTR9 Evaluation Board. for this board only one example has given. it is working. the path for this program is: ARM/RV30/BOARDS/KEIL/BLINKY. program is: #include <91x_lib.h> void delay(u32); int main (void) { SCU->GPIOOUT[7] = 0x5555; /* P7.0..7 output - mode 1 */ GPIO7->DDR = 0xFF; /* P7.0..7 Outputs (LED Data) */ while (1) { /* Loop forever */ GPIO7->DR[0x3FC] = 0xF0; /* Turn on LED */ delay(0x0FFF); GPIO7->DR[0x3FC] = 0x0F; /* Turn on LED */ delay(0x0FFF); } } void delay(u32 i) { u8 j; while(i-->0) for(j=0;j<=100;j++); }
The path for another program :ARM/RV30/BOARDS/ST/BLINKY ,with some modifications according to my board, is not working. i don't know why it is not working in my board(MCBSTR9 Evaluation Board).
the modified code which is not working in my board is:
#include "91x_lib.h" GPIO_InitTypeDef GPIO_InitStructure; u32 var; void SCU_Configuration(void); static void Delay(u32 nCount); int main() { #ifdef DEBUG debug(); #endif SCU_Configuration(); GPIO_StructInit(&GPIO_InitStructure); /* GPIO Configuration ------------------------------------*/ GPIO_DeInit(GPIO7); GPIO_InitStructure.GPIO_Direction = GPIO_PinOutput; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All; GPIO_InitStructure.GPIO_Type = GPIO_Type_PushPull ; GPIO_Init (GPIO7, &GPIO_InitStructure);
while(1) { GPIO7->DR[0x3FC] = 0xFF; Delay(0x0FF); GPIO7->DR[0x3FC] = 0x00; GPIO_WriteBit(GPIO7, GPIO_Pin_0, Bit_RESET); GPIO_WriteBit(GPIO7, GPIO_Pin_1, Bit_RESET); GPIO_WriteBit(GPIO7, GPIO_Pin_2, Bit_RESET); GPIO_WriteBit(GPIO7, GPIO_Pin_3, Bit_RESET); Delay(0x0FF); } } void SCU_Configuration(void) { SCU_APBPeriphClockConfig(__GPIO7 ,ENABLE); } static void Delay(u32 nCount) { u32 j = 0; for(j = nCount; j != 0; j--); }
to work this program in my board (MCBSTR9) what i have to do? Thanks in advance
regards raj.
Did you include the appropriate startup code?
Jon
