When I open the project of ST_Blinky embedded in uVision3, I can not select the Scatter File in the Options for Target dialog box. Is it because of using the evaluation one?
Blinky is an example, kind of 'gift' for keil simulation,
"I can not select the Scatter File in the Options for Target dialog box." ?? Click the option, and you select it, wats wrong with it?
Yes, this is a limitation in the evaluation version. See also: http://www.keil.com/demo/limits.asp
