hi there i strucked with the following problem. i am using the 89s52.from that i m using the one of timer as the counter,after some time i am going to stop the counter and the value(count) form the counter i want to shift or to load to the to another reg. how can i do this with the help of accumalator is fine but in which way as TH and TL is there how i move the data from these two to ACC. plz any one can explain me with proper example
A full amd complete list of all instructions available on the 8051 is here:
www.nxp.com/.../80C51_FAM_PROG_GUIDE_1.pdf
It's Chapter 2 of the so-called "bible" for the 8051 - 80C51 Family Programmer's Guide and Instruction Set
The other 2 Chapters are:
Chapter 1 - 80C51 Family Architecture: www.nxp.com/.../80C51_FAM_ARCH_1.pdf
Chapter 3 - 80C51 Family Hardware Description: www.nxp.com/.../80C51_FAM_HARDWARE_1.pdf
These are absolutely foundational for any work with the 8051.
You might also want to work through this Tutorial: www.8052.com/tutorial.phtml
as i said with the ACC is fine i.e i am aware of the mov instruction i am facing the problem when i collect the data suppose THMOVE from ACC to OTHER REG1 and TLMOVE from ACC to OTHER REG2 but when i want to combne it to the single number at that point what would i do as while loading the the value in to the we ex.AA00 AA moved to the TH and 00 moved to TL but when i retrived the data how i combined the data
On an 8-bit processor, you always have to do everything 8 bits at a time!
SO any 16-bit quantity will always have to be handled as two 8-bit values; low & high.
