Please help. I have been struggling for too long on this. How do I use printf to print any of the messages?
Is this the best way to use a table of varying length strings or is a struct devicestates {}; better, or must I specify fixed length strings in the struct?
char DeviceStates[4][2][25] = { {"closed", "open"}, {"down", "up"}, {"on;", "off"}, {"say not implemented;", "say is implemented;"} };
"Is this the best way..."
Depends on what you mean by "best"
It is certainly a very bad way if you are concerned to minimise the amount of storage used!
The whole point of arrays is that every element is the same - in your case, the strings vary greatly in length, so the short ones will be padded to the length of the longest ones. This wastes a lot of space - which may or may not be important to you.
You could avoid this by using pointers to the strings instead; eg,
char *DeviceStates[4][2] = { {"closed", "open"}, {"down", "up"}, {"on;", "off"}, {"say not implemented;", "say is implemented;"} };
