get compiler warning if unsigned variable is assigned with a signed value
Can I get a compiler warning if I accidentaly
assign a signed int to an unsigned int variable ?
eg:
unsigned int ui_par = 0 ; signed int si_par = -1 ;
Normally I would write something like:
ui_par = (WORD) (MAX(0,si_par)) ;
But if I accidentally do the following:
ui_par = si_par ;
=> ui_par = 65535
=> no compiler warning ?
  • 'C' is not a strongly-typed language, so compilers can't be relied upon to catch such mistakes - as they are not "errors" as far as the language is concerned.
    Some compilers might give a warning, though.
    You'll have to check in the appropriate Manual.
    You should use something like LINT to detect such mistakes, and/or use a strongly-typed language like Pascal...
