Problem with MCB167-NET
I'm using a C167 microcontroller for a project. In order to do some tests I'm using the MCB167-NET development board. It used to work correctly. However I have tried to use it today and I can't connect to the board via uvision2.
When I start the debug session I got the message "CONNECTION TO TARGET LOST".
I have check the COM port and it is correct.
I can't debug any program (I tried the samples as hello and blinky as describe in the user's guide). I have tried to connect with flashtools also but it doesn't work either.
By the way, I can connect to the C167 card with flashtools without any problem. (That's I eventually did but I would prefer to use the development board)
Is there any hard reset or something like that I could do?
Thanks a lot for your help.
Stephane
