Building and compiling uv2 project from batch file instead of uv IDE
Hello All,
I am trying to understand how to build a uv2 project from command line.
Presently when the (eg test.uv2) project is clicked open, it defaults to the uv2 IDE for build, compile and link.
Is there any way,that a project can be built, compiled and linked from command line without resorting to the IDE?
The idea is that someone without a knowledge of the IDE, should simply be able to compile the project with a given set of instructions.
Thanks in advance.
I look forward for your suggestions.
