Sir, Here is my UART program... $ org 000h ljmp begin org 23h ljmp serial_IT ;/** ; * FUNCTION_PURPOSE: This file set up uart in mode 1 (8 bits uart) with ; * timer 1 in mode 2 (8 bits auto reload timer). ; * FUNCTION_INPUTS: void ; * FUNCTION_OUTPUTS: void ; */ org 0100h begin: MOV SCON, #50h; /* uart in mode 1 (8 bit), REN=1 */ ORL TMOD, #20h; /* Timer 1 in mode 2 */ MOV TH1, #0FDh; /* 9600 Bds at 11.059MHz */ MOV TL1, #0FDh; /* 9600 Bds at 11.059MHz */ SETB ES; /* Enable serial interrupt*/ SETB EA; /* Enable global interrupt */ SETB TR1; /* Timer 1 run */ JMP $; /* endless */ ;/** ; * FUNCTION_PURPOSE: serial interrupt, echo received data. ; * FUNCTION_INPUTS: P3.0(RXD) serial input ; * FUNCTION_OUTPUTS: P3.1(TXD) serial output ; */ serial_IT: JNB RI,EMIT_IT ; test if it is a reception CLR RI ; clear reception flag for next reception MOV A,SBUF ; read data from uart MOV SBUF,A ; write same data to uart LJMP END_IT EMIT_IT: CLR TI ; clear transmition flag for next transmition END_IT: RETI end This program is taken from ATMEL SITe.. when i simulate it....during simulation how do i give serial input? When u just run it,setting RI manually...check out SBUF value...no value in it??? How to give serial input?? Since port 3 (P3.0 (RXD) and P3.1 (TXD) ) is used for serial communication.. how to set p3.1 as output pin and p3.0 as input pin?? Thank you. Tushar
Use the Serial Window
HOw do i make use of serial window? when i try to give the input from keyboard..nothing comes up on th window... Plz tell me in deatil Thank you.. Tushar
Please read the uVision Getting Started Guide, and work through the example projects in it. This will give you a proper introduction to the tools, how they work, and how to use them - rather than just jumping-in blindly at the deep end. (The uVision Getting Started Guide is available on the 'Books' tab in the 'Project' Window; The 'Books' window is also available via the 'Help' menu; failing all that, search for GS51.PDF in your Keil folder)
Hi u can visualize it on ports
Sir, Thnx for ur help..my program is runnning successfully now...i can give the input and print the output on serial window... Still hv some questions regarding serial window. In my hardware module i am using P3.0 as RXD and P3.1 as TXD. NOTE :: P3.0 and P3.1 are not connected to the serial port of computer. They are connected to RX and TX pins of RF transmitter/Receiver module. Now when i give the input through serial window how do i come to know that it is coming from P3.0 (Or by default it comes from there only?) Same is the case when i am transmitting...how do i come to know whether character that i am transmitting gets transmitted from P3.1?
"NOTE :: P3.0 and P3.1 are not connected to the serial port of computer. They are connected to RX and TX pins of RF transmitter/Receiver module." But in the Simulator they are not connected to anything at all - they don't even exist!! "Now when i give the input through serial window how do i come to know that it is coming from P3.0" Typing in the Serial Window simulates data arriving at P3.0 "Same is the case when i am transmitting...how do i come to know whether character that i am transmitting gets transmitted from P3.1?" It doesn't - it appears in the Serial Windows to simulate data being transmitted from P3.1!
