Hello, In my program, I call C function form assembly main code. But sometimes while excuting the C functions, the program jumps back to the Assembly code!!!! Have this happened to anyone? I'm using Level 9 optimize (because my code is very big). Thanks.
the program jumps back to the Assembly code!!!! Are you sure that's the Assembly code, as opposed to, say, just some code that the debugger couldn't find C source for? I'm using Level 9 optimize (because my code is very big). Try to understand what the optimizations done at that level actually mean, and this should clear itself up. Here's a hint: what might "common tail merging" be?
Oh, thanks for quick answer. But I've figured out the reason. That's all about my Stack size. In the assembly program, I initilized the stack size is 32 bytes and that is not enough for the whole new program, with C functions. Thanks again. P/s: about the optimize level, because when I compile my program with Level 8, it made the code size was over 100 KiloBytes, over my flash memory which is only 64KB. So I use the Level 9, and the code size reduced to 63KB, and that is all I need.
"not enough for the whole new program, with C functions." The "with 'C' functions" bit is irrelevant: C51 functions use no more stack than assembler functions, as they do not use the stack for parameters, locals, etc.
Nguyen, you use OT 9 and your Stack get overflowed? Then see my explanation in the thread "Disappointing optimisation..." at http://www.keil.com/forum/docs/thread5269.asp Hint: Observe in *.LST output files how the compiler generates binary code with optimizing level 9 (e.g. comparing with OT 8). Martin
