disassembly of thumb code
If I set a breakpoint shortly after my main() routine (which runs in thumb mode), the disassembly window shows arm code when the breakpoint is hit. Stepping is really weird because the PC advances by only 2 bytes, but the window still tries to show 4-byte instructions. The CPSR clearly indicates that we are in thumb mode.
Similarly, if I try the u (unassemble) command, it also shows arm instructions. I could not find any extra parameters for the u command to tell it what kind of disassembly to do nor could I find any options for the disassembly window. Is there a way to force this window to show arm or thumb?
