Evaluation Software: c51 8.01 O.S : Win2000 ********************************** Problem: I have downloaded the evaluation software in d drive from keil website.And installed it in that system in c drive.It was working fine.But due to system problem i had to re-install the O.S.Now I have taken the dump keil .exe file from my D drive was trying to install c compiler.This are the problem i was facing...... 1) When i click on the .exe file icon it was saying that "Cannot load LICENCE.RTF file 2) After clicking OK button ,in the middle of installation i.e after the customer Information window it says, "cannot install the program files to the specified destination folder.Please make sure that this folder is not write-protected and that enough space is available on the destination drive." I have checked the drive space and etc.there is no issues. So what i want to know is if i download the keil c51 compiler from website,then this software can be installed only once ??If i want to install this again do i need to download a fresh copy of this again?? Pls help!! Thanks, DCD
Why don't you just re-install from the download again? Simply copying EXEs (almost) never works with Windows applications...
Thank you sir for the reply. I was not copying .exe file.Instead I was installing c51 from already downloaded .exe setup file(which is in my D drive).What could be problem? thanks, dcd
