is this possible
It happened again.
I have many cases of modules with something like
#ifdef TYPEA
... many lines
#endif
#ifdef TYPEB
... many similar lines
#endif
#ifdef TYPEC
#endif
It happens that I am looking at the type b code trying to figure out something in type a (the codes are VERY similar).
To avoid this, I have tried
blah,blah // comment TYPEA
and that "kind of works"
Now, the ideal would be if for type a I could do the following:
#ifdef TYPEA
#define ATYPE
#define BTYPE //
#define CTYPE //
#endif
and then just make it
ATYPE blah,blah // comment
Of course this does not work.
Does anyone have a trick that makes this possible?
  • I would strongly recommend putting this stuff in three different files instead.
    If you really want to keep on putting all these in a single file, you'll have to encapsulate statements, not blocks or lines:
    --- a.c ---
    #define TYPE_A(x) x
    #define TYPE_B(x) /* nothing */
    #define TYPE_C(x) /* nothing */
    #include "abc.c"
  • You know that CodeWright can hide code that's inactivated by #if...?
    Already done where practical.
    I do, but never figured out how to make it work when the file with #define TYPEA is in the same subdirectory as the file with #define TYPEB and neither #defines are in the file being looked at.
  • you'll have to encapsulate statements, not blocks or lines:
    --- a.c ---
    #define TYPE_A(x) x
    That one I do not understand
  • How about something like:
    #if ATYPE
    #define ATYPE
    #define BTYPE  if (0)
    #define CTYPE  if (0)
    #endif
    ATYPE
        code;
        goes;
        here;
    BTYPE
        other;
        code;
        here;
    CTYPE
        less;
        code;
    The optimizer should take out the dead code. The brackets help make it very clear where the extent of the variant code lies. You can also nest blocks inside of them without worries about comment styles.
  • what the optimizer does is irrelevant, that works just fine with #define. The issue is to find a means that, at the beinning of each line, identify the type when looking at it in CodeWright.
    so, instead of
    #ifdef TYPEA
    aline1
    aline2
    aline3
    #endif
    #ifdef TYPEB
    bline1
    bline2
    bline3
    #endif
    it would look like this
    TYPEA aline1
    TYPEA aline2
    TYPEA aline3
    TYPEB bline1
    TYPEB bline2
    TYPEB bline3
    just dreaming, I know, but sometimes a dream can come true :)
  • That one I do not understand
    Strange, given it does exactly what you tried to achieve, just differently enough to get it to work. You wanted to write
    TYPEA  code for a;
    TYPEB  code for variant b;
    TYPEC  code vor variant c;
    The macros I've shown allow to do that, but you'll have to spell it a bit differently:
    TYPEA(code for a);
    TYPEB(code for variant b);
    TYPEC(code vor variant c);
    and this syntax will pose some constraints on what you can write as "code for ...".
    If you do it the way you want, you'll confuse CodeWright no end --- it'll lose track of the C syntax of your code. You'll basically lose most of the advantage a programmers' editor has over Notepad.
    You may want to reconsider whether you really have to edit the same file that the compiler will get to see. The C preprocessor is not the be-all and end-all of on-the-fly source code manipulation. You could preprocess a single ".cin" file with Perl or similar tools to generate multiple .c files and feed only those to the compiler.
  • I guess the extra parentheses would be confoosing, i will write a few lines and judge
    thanx
  • and feed only those to the compiler.
    The problem is when I look at the code in the editor, it is almost never clear which group of code I am looking at.
    My code generate 47 different builds and maintaining them as separate 'projects' would never work (a fix to the common code implemented in 46 and missed in one)
  • "I would strongly recommend putting this stuff in three different files instead"
    "Already done where practical." One idea I have depends on why the separate files are impractical. Could you elaborate, please?
  • "Already done where practical." One idea I have depends on why the separate files are impractical. Could you elaborate, please?
    I have modules that are, say, 80% different fron group a to groupb to groupn and those are in separate modules that the .bat make select based on which of the 47 versions is to be build.
    for modules that are, say, 20% different and have very many flavors, maintaining the common code in that many modules would be extremely impractical.
    To the greatest extent possible where the difference is, say, a function, that function have been separated out.
    The issues where the original query relate are where you have, say a function that is 93% the same, but in minor details is different.
    This all relates to a) an inherited project which was a total mess, but now with some use of macros etc i quite a bit cleaner and b) to my new design wher the 'mess' is geatly reduced, but everything can be improved on.
    Thanks for the interest
  • The problem is when I look at the code in the editor, it is almost never clear which group of code I am looking at.
    That much was clear from the beginning.
    You don't seem to grasp what I'm suggesting, though. My proposal is to avoid this gotcha by not having the actual C code to look at. And the method of doing that is to provide C source only while it's being fed to the compiler: create a C file for variant A from the common, not-quite-C code file, compile it, and if the compile went well, delete the temp file. Then do the same for variant B.
    The benefit is that instead of C preprocessor macros, you can use whatever syntax you like to indicate what platform any file is for, as long as you have a tool that can translate it to C. You could even actually have your "combined C file" look like your original idea. A simple little 'sed' script could decode that. In pseudo-shell syntax:
    sed -e '/^TYPE[^A]/d' module.cin' | c51
  • You don't seem to grasp what I'm suggesting, though. My proposal is to avoid this gotcha by not having the actual C code to look at. And the method of doing that is to provide C source only while it's being fed to the compiler: create a C file for variant A from the common, not-quite-C code file, compile it, and if the compile went well, delete the temp file. Then do the same for variant B through m.
    That process is waaaaay to likely to miss one variant, I have, believe me, tried it and failed.
    To do so, you have to rely on the so called "testing" and that would be a true disater.
    The suggestion, although dismissed, is still appreacited, Thanks
