Hi, I have MCB900 board V4 (with 89LPC936). At first time, I can program with KEIL (v8.02) which is using FM.EXE (flash Magic). Then, I tried to use ISD Demo program, it can be programmed. After that, I disconnected the board and programmed again but it was not successful and got the following error messages.
Flash Magic Version 3.32.156 8051/XA Driver Version 2.22.156 ARM Driver Version 1.16.154 (C) Embedded Systems Academy 2000-2006 All rights reserved Connected Device selected Erase failed: invalid command (DEVICE)
Note: If I used Flash Magic (windows version), I can program successfully. Any idea?
Thank in adavanced, pak
I recommend that you try with an older FlashMagic Version. I have used FlashMagic V2.34 and it worked just fine.
