Hello, With the help of one example <EX22-SPI> I want to drive an FRAM with a hardware SPI on an LPC2114. This example code uses interrupts to read and write data. Is it mandatory? Who has such code? Thank you
unsigned char status = 0; unsigned char SPI_bytecount = 0; unsigned char * SPI_buffer; volatile unsigned char lock = 0; unsigned char input_buffer[8]; void main (void) { unsigned char output_buffer[8] = {1,2,3,4,5,6,7,8}; PINSEL0 = 0x00005500; //Enable SPI0 pins IODIR0 = 0x00000400; //Enable Chipselect pin as output S0SPCCR = 0x000000FF; //Set bit timing S0SPCR = 0x000000A0; //Configure as SPI Master interrupts enabled VICVectCntl0 = 0x0000002A; //Select a priority slot for a given interrupt VICVectAddr0 = (unsigned)SPI_ISR; //Pass the address of the IRQ into the VIC slot VICIntEnable = 0x00000400; //Enable interrupt SPI_write(output_buffer,8); //Write eight bytes to the memory while(lock) { ; } SPI_read(input_buffer,8); //Read them back IOCLR0 = input_buffer[0]; while(1) { ; } } void SPI_write(unsigned char *buffer,unsigned char bytecount) { lock = 1; SPI_buffer = buffer; SPI_bytecount = bytecount; IOCLR0 = 0x00000400; //Pull Chipselect low S0SPDR = 0x00000006; //Send WRITE opcode status = 0x01; //set next state } void SPI_read(unsigned char *buffer,unsigned char bytecount) { SPI_buffer = buffer; SPI_bytecount = bytecount; IOCLR0 = 0x00000400; //Pull Chipselect low S0SPDR = 0x00000003; //Send READ code status = 0x05; //set next state } void SPI_ISR (void) __irq { unsigned char result; unsigned int test; switch(status) { case (0x01): //Send Write opcode S0SPDR = 0x00000002; status = 0x02; //set next state break; case (0x02): //Send Write Address S0SPDR = 0x00000000; status = 0x03; //Set next state break; case (0x03): //write data S0SPDR = *SPI_buffer++; if( --SPI_bytecount) { status = 0x03; //Set Next state } else { status = 0x04; //End condition } break; case (0x04): //End condition S0SPDR = 0x00000055; //Need this dummy write for simulation IOSET0 = 0x00000400; //Pull Chipselect high status = 0x07; //jump to null case break; case (0x05): S0SPDR = 0x00000000; //Send Address status = 0x06; //set next state break; case (0x06): *SPI_buffer = S0SPDR; //read data S0SPDR = 0xFF; //Send Address SPI_buffer++; if( --SPI_bytecount) { status = 0x06; //Set Next state } else { status = 0x07; //End condition } break; case (0x07) : //Null Case lock = 0; break; default : break; } S0SPINT = 0x01; //Signal end of interrupt VICVectAddr = 0x00000000; //Dummy write to signal end of interrupt }
