Hi all, i use a Lauterbach TRACE32-ICD, which has a parallel and also an ethernet port. At the moment i'm using the ethernet interface. I just downloaded the ARM evaluation tools and wanted to set up uVision together with the TRACE32-ICD, but i don't exactly know how to do this. Can anyone help? Thanks in advance. Alex
We use Lauterbach uTrace for ARM Cortex debugging and Keil uVision as IDE. Is it possible to debug from Keil using Lauterbach uTrace and the HW debugger interface.
Thank you.
Regards,
Chandrasekar
Note that the post was from 15 years ago - so unlikely that Alex Efe is still in need of this information!
