I have read in the ADuC832's datasheet that the SFRs P2 and P3 are bit addressable, but the evaluation version of uVision2 doesn't allow to do it (I have a syntax error when I use - for example - the code line P2.3 =0x03) Is it a problem related to an incorrect code or does it depend from the fact that I have an uVision2's evaluation version? The full version of uVision2 allow to address bit by bit the SFRs P2 and P3?
Excuse me I want to say "Does the full version of uVision2 allow to address bit by bit the SFRs P2 and P3?"
both the eval and the full allow bit addressing if you do it as stated in the manual Erik
"Is it a problem related to an incorrect code" Yes, it is. Your syntax is wrong - check the Manual for the correct Keil-specific 'C' syntax extension.
And what does the manual state, in this case?
Ok! Thank you! I have already started reading the Cx51 Compiler's manual supplied with uVision2!
Beautiful! I have solved my problem, but not reading the manual!!!! I have opened some files of the Analog Devices! Thank you for all!
