It should be fairly straightforward to write and read a 25xxx eeprom thru the SPI bus using the pc serial port with Keil software. But nowhere do I find the DB-9 to SPI connections. Which pins connects to sck, mosi, miso,cs ? Can you help? Thanks, John
"But nowhere do I find the DB-9 to SPI connections." That's because there is no standard for that type of connection. FWIW, I happen to have used TD<->SCK, DTR<->MOSI, and CTS<->MISO through RS-232 transceivers for some bit-banged applications.
Opps, guess the keil software doesnt actually write the code to the eeprom then ?
Are you talking about Keil's uVision IDE and/or a Keil ISP application? Is the target a Keil development board (or other Keil-supported development board) that has an external (to the MCU) EEPROM used to hold your application code and that the Keil tools would know how to program?
Opps, guess the keil software doesnt actually write the code to the eeprom then ? Keil does not write code, they provide the tools for you to write the code. Also, it would be nice to know which derivative you use, some have hardware SPI Erik
I'm a hardware guy. What Im doing is designing the hardware that plugs into a pc serial port and connects to the external 25xx320 eeprom of a nrf9e5 chip. And dont know a whole lot about software.
"What Im doing is designing the hardware that plugs into a pc serial port and connects to the external 25xx320 eeprom of a nrf9e5 chip." Ah, your queries make much more sense now that I understand the context. So now a few comments:
Thanks, winburn looks like a good place to start reading. Are you working with the Nordic chip ? The EVboard uses the usb but probably thru a 232 to usb translator chip. They dont seem inclined to release the sch files for their programming dongle.
"Are you working with the Nordic chip ?" No, but I have developed firmware for numerous "low end" RF systems and a few "high end" RF systems. The Nordic part looks like an interesting device at a glance.
It's good meeting you. I'll let you know how it goes. john
"It's good meeting you." Likewise. "I'll let you know how it goes." Yes, please do.
Installed winburn - looks good so far but I dont see mention of the db9 to spi connection yet.
Perhaps we're supposed to read between the lines and infer that WinBurn does not directly program, but instead talks to the MCU for it to perform the programming on behalf of WinBurn. That would be a pity.
Either way it appears to be a dead end for me. He wants $995 for the schematic. Hell, thats more than I'm planning on spending on putting this thing into prototype production. Was gonna post this at the 8052.com but Ill run it up here: Here's my problem: I'm designing the hardware that allows program hex code to be loaded to an external eeprom (25230 type) that is used in conjunction with a Nordic nRF9E5 chip. The nRF9E5 contains an 8051 type mpu and requires it's program code to reside in the external eeprom. The eeprom uses the SPI bus. I want to use a windows based pc serial port. Actuall the usb but a 232 to usb translator chip and virtual comm port. But that part is understood. So, since there is no standard for this type of thing, just which db9 pins connect to sck, mosi, miso is determined by the software that loads the hex. So far Ive only found a nice windows app that costs $995 USD. Out of the question. Any help will be greatly appreciated. One other thing. Has anyone any familiarity with dss hacking a few years back ? As I recall the hu card contained an 8051 and 8k eeprom and was programmed via an iso7816 programmer thru the serial port. Wasnt this really an SPI interface ? john
dead simple If you buy a Keil MCB900 board (<$50 at discount) and connect it to a zif socket for the eeprom on the patchboard. The LPC93x has HW SPI and a UART (the MCB900 even has the DB9 socket and the transciever on it). Then you get most of the code generated by using the CodeArchitect for LPC932, free from http://www.esacademy.com. So, <$50, a ZIF socket and a day of coding How dat? Erik
Thanks, dat be worth lookin into fer sure. which I will do almost immediately !
