Problem with writing and reading from AT93C46 (memory device)
Hi
I am experiencing a problem with AT9346 as my could not get the reading from memory by displaying 8 LEDs in order to let me know that the content of memory at address 0x00 has been read. Unfortunately nothing happened yet! :-(
// header files
#include "main.h"
#include "port.h"
#include "delay_loop.h"
//global variables
//Function Prototypes
void write_command(unsigned char DATA);
void read_command(unsigned char ADDRESS);
void send_clock();
void process(unsigned char byte);
void EW_enable();
void EW_disable();
//void Erase_command();
void send_clock()
   PULSE_CLOCK=1;
   PULSE_CLOCK=0;
   unsigned char k,nbit;
   for(k=1;k<=8;k++)
      nbit= byte & 0x80;
      if (nbit != 0)
      DIN=1;
      else
      DIN=0;
      send_clock();
      byte=byte <<1;
   unsigned char i,m,d=0,loop=8;
   CS=1;
   //Send two 1s (Dummies data)
   for(i=1; i<=2; i++)
   DIN=1;
   send_clock();
   process(ADDRESS);
   for(m=0;m<=8;m++)
   d=d | DOUT;
   send_clock();
      if(loop !=0)
         d=d<<1;
      loop--;
   CS=0;
   CS=1;
   CS=0;
   P1=d;  //Send result to P1 (leds)
   unsigned char const location=0x00;
   CS=1;
   // Transmit 1,1,0
   DIN=1;
   send_clock();
   DIN=0;
   send_clock();
   DIN=1;
   send_clock();
   process(location); //Select address
   process(DATA);     //Write data
   CS=0;
   CS=1;
   CS=0;
void EW_enable()
   CS=1;
   DIN=1;
   send_clock();
   DIN=0;
   send_clock();
   process(0x7F);
   CS=0;
   CS=1;
void EW_disable()
   CS=1;
   DIN=1;
   send_clock();
   DIN=0;
   send_clock();
   process(0x30);
   CS=0;
   CS=1;
   CS=1;
   DIN=1;
   send_clock();
   DIN=1;
   send_clock();
   DIN=1;
   send_clock();
   process(0x00);     //Erase Data at address 0x00
   CS=0;
   CS=1;
void main(void)
      P1=0;
      CS=0;
      DIN=0;
      DOUT=0;
      PULSE_CLOCK=0;
      EW_enable();
      write_command(0xFF);
      Delay_Loop(200);
      read_command(0x00); //Read data at address 0x00
      EW_disable();
Any help would be greatly appreicated
Confusedman
