using I2c interface to connect ARM LPC2132 to serial EEPROM
Hi all,
I am tryin to interface serial EEprom CAT24WC01 to ARM based LPC2132 using I2C only.
Has anyone worked on this set up before , or has anyone already written drivers for same already ?
If someone has already done this please send me info about this ... I am in kind of a hurry to finish this .
Regards
Amit
  • My Programm is for ADuC7026 and 24C16.
    Maybee helpful.
    Some registernames are to be adapted.
    //my global variables
    unsigned char dat[2048];
    unsigned int i,k;
    void eeprom_read()
            for(k=0;k<256;k++)
                    i = 0;
                    I2C1ADR = 0xA0+((k>>5)<<1); // set i2c address(LSB = 0, Master Write)
                    I2C1MTX = (k<<3)&255;         // send i2c byte address
                    delay(4000);
                    I2C1ADR = 0xA1+((k>>5)<<1); // set i2c address(LSB = 1, Master Read)
                    I2C1CNT = 7;                            // 8 bytes to be read from slave
                    while(i < 8){}
    void IRQ_Handler() __irq __ram
            if(I2C1MSTA & 0x8) dat[(k<<3)+i++] = I2C1MRX;
