Keil\ARM\GNU Boards\ADI\Aduc7020X\Blinky\Blinky.Uv2
--- Error: can't execute 'gcc'
I have installed Cygnus and Keil and am unable to get it to compile or even access the GCC compiler
It worked two days ago but after I actually had the thing working it refused to compile again, after a removal and reinstall it worked exactly once. Then I get the above message. WHAT IS GOIN ON?
Have you checked Compiler option ??
There are various options..Eg. * use Keil Tools or *GNU tools for you project.
Works just fine on my computer. The settings for GNU are in Project - Components, Environment and Books - Folders/Extensions.
GNU-Tool-Prefix: arm-uclibc- Cygnus Folder: C:\Cygnus
You can try this setting: http://www.keil.com/forum/docs/thread8537.asp
It is a litle bit more complex, but it works also with the latest GNU ARM packages.
