This is regarding the 'LPC2148 USB audio example' available in this site. I have some confusions regarding the codes. The endpoint 3(out) is supposed to use DMA here. But in the SOF event callback, data is transferred from EP_RAM to buffer by calling the read endpoint function, similar to slave mode transfer and thus not involving dma. need clarification on this.
The 'LPC2148 USB Audio' is configured not to use the DMA. But it is very simple to configure it to use the DMA. This can be achieved by enabling the 'DMA Transfer' under 'USB Configuration' in the 'usbcfg.h' file with the Configuration Wizard. Also the Linker settings must be updated by disabling the option 'Use Memory Layout from Target Dialog' and by selecting the '.\DMA.sct' for the Scatter File.
I am using the lpc2148. I want to use dma transfer from an external flash memory to an audio codec. please tell me how to go about this. thank u
