Porting STR Webserver Example to Keil
i want to port the STR912F webserver example from St with the uip stack to Keil. Unfortunately the startup files 91x_init.s and 91x_vect.s could not be assebled by ulink 3 it seems that Keil ist incompatible to this files. By using the STR91x startup file from Keil the webserver don´t works.
Has anyone a hint for solving this problem?
Björn
