Hi guys,
I wrote a simple program using the data in small model and the code in large model, and the program worked perfectly, however, when I compiled the program with the data in large model, the program compiles, but it does not run!!!!
Does anyone have any clues about why this happen?
Thanks in advanced,
DB
Do you have any xdata? If you don't, the large memory model won't work.
Jon
If your system has XDATA, does it need to be enabled somehow before you can use it?
If you try to use it without first doing necessary initialisations, you will obviously fail!
"the program compiles, but it does not run!!!!"
You must understand that the fact that a program builds is no guarantee that it will run at all - let alone run as you intended!
The fact that a program builds just shows that you haven't broken any syntax rules.
Does the program give any warnings when it builds? Warnings will (usually) not prevent the program from building but may well point to the reason why it doesn't run, or doesn't run properly.
Possible causes:
1. Your device (the type of which you did not state) does not have any xdata memory.
Solution: Consult the appropriate datasheet. Chose a different device if no xdata memory is available on yours.
2. Your device does have internal xdata memory, but it is disabled by default and needs to be enabled first.
Solution: Consult the appropriate datasheet. Modify your startup file to enable XRAM.
3. Your board has external XDATA memory and is faulty.
Solution: Contact your hardware engineer.
4. Your board has external XDATA memory, but you have not configured it properly (eg, enable it; timings) and/or you are not using it correctly (eg, you are using the wrong address range).
Solution: again, Contact your hardware engineer, or consult the documentation for your board.
Thanks to all the guys that respended.... I should have answered your questions before....
1.- Yes, I have several xdata variables defined. 2.- I do not get any warnings in the compilation. 3.- I wrote a routine to check the RAM and it was all OK.
I can run my program with my cvariables in xdata in the data small model (the code is in the LARGE model), however, if I try to compile the data in LARGE model it does not run at all!
Does nayone has any more clues about what is going on? What can I do to make it run?
Thanks in advanced....
"I should have answered your questions before...."
Yes - unfortunately, you still haven't answered the questions that where actually asked!
"1.- Yes, I have several xdata variables defined."
The question was not, "do you use XDATA?"; The question was, "is there any XDATA memory physically present in your system?"
And the corollary is, "do you correctly enable and/or configure the physical XDATA memory in your system?"
"3.- I wrote a routine to check the RAM and it was all OK."
Maybe your routine was flawed? I knew someone who wrote a memory test, and it gave a "Pass" even when no memory chips were fitted in the board! You need a thorough understanding of how memory systems work, and the possible failure mechanisms, to be able to write an effective memory test. Read this article for further details: www.embedded.com/.../0007feat1.htm
But first you need to ensure that your usage of the memory is correct!
"it does not run at all!"
How do you determine that? What indications would your program give if it was working?
Note that accessing XDATA is significantly slower than DATA and IDATA - so, if your timing was marginal with the SMALL model, switching to LARGE could easily tip it over the edge and stop it working!
http://www.keil.com/forum/docs/thread8227.asp
Hi, I dont know if this will help but if your code space is the same as XDATA memory (von neumann) and you switch from small to large without setting the "off chip xdata memory" field on the Target tab of the "target options" dialog, then the xdata variables will overwrite the code and corrupt it. This would show up in simulation if you can set code = xdata but I dont know how to do that.
