Serial communication in C
The serial communication with my self-made 8031 board works in assembler (beneath) but it does not work properly with C code doing the same. Anyone to know what the problem may be? Thanks
NAME SAMPLE
DS 10H
CSEG AT 0A100h
START: MOV SP,#50
; Oscillator frequency = 11.059 MHz
MOV TMOD,#00100000B ;C/T = 0, Mode = 2
MOV TH1,#0FDH
SETB TR1
MOV SCON,#01010010B
MOV A, #"a"
REPEAT:
JNB TI,$
CLR TI
MOV SBUF,A
SJMP REPEAT
END
  • "does not work properly with C code doing the same. Anyone to know what the problem may be?"
    Obviously, the 'C' code is not quite doing the same!
    Without seeing your 'C' code, how can anyone comment further?
    Please read the instructions (3 bullet points immediately above the 'Message' box) before posting code.
    Have you tried the simple "Hello, World" 'C' example shipped with the compiler?
    Have you tried it in the simulator?
  • #pragma iv(0xA000)
    #include "reg51.h"
    #include <stdio.h>
    void main (void){
      TMOD = 0x20;
      TH1 = 0xFD;
      TR1 = 1;
      SCON = 0x52;
      //printf("a");
    This is my C code.
    The board sends 06h 02h 01h 05h 0BFh 0CAh 04h 05h even without calling the printf function.
    "Hello word" works the same way. When usig simulator, everything is ok.
