Has anyone any idea where I can get a double precision maths library which will work with the Keil C51 compiler.
If it is 64-bit floating point you are looking for, I don't think that you will find it. It is possible to do 64-bit fixed point arithmetic, but you already know about that: http://www.keil.com/forum/docs/thread7167.asp
I s'pose it depends on what exactly you mean by, "will work with the Keil C51 compiler." ... ??
I believe the C51 compiler will only accept float (32bit)types and will not recognise the double & long double(64bit) types.
"I believe the C51 compiler will only accept float (32bit)types and will not recognise the double & long double(64bit) types." That's the C51 implementation itself - but you were asking about an add-on library. What exactly do you want of this library to constitute "working" with C51?
We have found whilst doing a project that we need to do some calculations which require greater than 11 digits of accuracy. The normal float only supplies 7/8! We have done the calculations in Visual C++ but the only way to get them to work properly was to use double types. When the code is transported to C51 the inaccuracies are too great.
"We have found whilst doing a project that we need to do some calculations which require greater than 11 digits of accuracy." Now, how about the range requirements? If you don't need the range that having an exponent gives you, then a using 64-bit fixed-point format might do the trick.
Unfortunately, we need a range which includes numbers from 0.0005--- to 16,000,000^3 both positive and negative. We have looked into using 64bit integers but this requires an aweful lot of extra scaling which we feel would be easier to achieved in fp.
how lovely achieved in fp is that "fixed point" or "floating point" ambigous abbreviations hurt when you sit down. erik
I'd always assumed fp meant 'Floating Point' and nothing else!
I'd always assumed fp meant 'Floating Point' and nothing else! And post by the assupmption that someone reading this in Farawyistan makes the same assumption. Erik
We seem to have lost the thread! Double precision maths for the 8051 - any ideas?
"Double precision maths for the 8051 - any ideas?" I thought you had it when you said, "Many thanks Graham. That will do nicely with some slight modifications." in your previous thread?! http://www.keil.com/forum/docs/thread7167.asp
Hello Dave Have never used the forum before, but I have been driven here by the same need... my project required greater precision than 'float' & I have discovered the hard way that the Keil tools (otherwise very good) ignore the 'double' declaration. You can get a double precision maths library that Keil claim will do the job... it's called GoFast from microdigital (see http://www.smxinfo.com) but it costs around $5,000. I cannot justify the cost as all I need is the four basic functions (+ - / and *). I have had a quick look at the problem & it seems this could be done as C functions (using a union to create the data type & writing functions to do the maths) - if this is all you need, do you want to collaborate on writing & testing these? BR Paul
Can you still buy those 8087 maths co-processors...?
Hello Andy I am new to using forums, so not sure if I am supposed to answer this or was it for the originator - anyway... not sure about availability of 8087s, but in my case the hardware is fixed so I will work towards a firmware solution. thanks - Paul
