Hi i m using nrf24E1 board when i flashed the prog i cant get the result porperly while the i got the result on serial window 1 of keil .sometime board can get data from keyboard and most time it just display the data and cant get from keyboard, My serial port and baud rate are correct , i m using tera term. pre #include <Nordic\reg24e1.h> #include <stdio.h> void Init(void){ TH1 = 243; // 19200@16MHz (when T1M=1 and SMOD=1) CKCON |= 0x10; // T1M=1 (/4 timer clock) PCON = 0x80; // SMOD=1 (double baud rate) SCON = 0x52; // Serial mode1, enable receiver TMOD = 0x20; // Timer1 8bit auto reload TR1 = 1; // Start timer1 P0_DIR |= 0x02; // P0.1 (RxD) is an input P0_ALT |= 0x06; // Select alternate functions on pins P0.1 and P0.2 EA=1; } /*------------------------------------------------ ------------------------------------------------*/ char putchar (char c) { while (!TI); TI = 0; SBUF = c; return (c); } /*------------------------------------------------ ------------------------------------------------*/ char getchar (void) { char c; while (!RI); c = SBUF; RI = 0; return (c); } main(void){ char c; Init(); while (1) { printf("Press a key: "); c = getchar (); printf("\r\nYou pressed %c\r\n", c); } } /pre
