hai Iam new to this how can i configure a timer to run as a one second timer.for every second it must count .plz some example code please
A simple start would be to write the value 0xRTFM to your TH1 register.
However for more details you will have to check the reference manual of your proccessor.
A simple start would be to write the value 0xRTFM to your TH1 register. :) I enjoyed that one
anyhow, since you say "Iam new to this" do not do anything till you are familar with "the bible"
here are the links to "the bible" Chapter 1 www.semiconductors.philips.com/.../80C51_FAM_ARCH_1.pdf
chapter 2 www.semiconductors.philips.com/.../80C51_FAM_PROG_GUIDE_1.pdf
chapter 3 www.semiconductors.philips.com/.../80C51_FAM_HARDWARE_1.pdf
