C: bdata unsigned BUFR16=0; sbit BIT8=BUFR16^8; the assemble language which is compiled by Keil uVision3: C:0x1172 9210 MOV BIT8(0x22.0),C ...... ;BUFR16<<=1; C:0x117D E522 MOV A,0x22 C:0x117F 25E0 ADD A,ACC(0xE0) C:0x1181 F522 MOV 0x22,A C:0x1183 E521 MOV A,BUFR16(0x21) C:0x1185 33 RLC A C:0x1186 F521 MOV BUFR16(0x21),A ......
"bdata unsigned BUFR16=0; sbit BIT8=BUFR16^8;" These just define two symbols - BUFR16, and BIT8 - they do not actually generate any code. You need to show the source line for that assembler that you quoted.
At a guess, the question has something to do with the bit ordering within a U16 declared in bdata. See the note at the end of the Bit-Addressable Objects section in Chapter 3 of the compiler manual. The sbit data type uses the specified variable as a base address and adds the bit position to obtain a physical bit address. Physical bit addresses are not equivalent to logical bit positions for certain data types. Physical bit position 0 refers to bit position 0 of the first byte. Physical bit position 8 refers to bit position 0 of the second byte. Because int variables are stored high-byte first, bit 0 of the integer is located in bit position 0 of the second byte. This is physical bit position 8 when accessed using an sbit data type.
well,because the int variable stored high-byte first, but the compiler(Physical bit position) consider low-byte first in bdata area, so this question is appeared. And so it will be thought to be a bug.
Yes, it's always confusing when the same platform uses different big- and little- endian numbering for the bytes and bits.
The 8051 bit addresses start at the LSB of location 20H, increment to the MSB of location 20H, and then to the LSB of location 21H. Bit 8 is the LSB of 21H. Bit 7F is the MSB of location 2FH.
