Hi, I have a project passed down by other ppl. I have an existing main.a51 and a HEX file. I'm using uVision2 for this prjt, but i do not know how to start with it as most of the example i saw is written in C. Are they the same? That means i add the assembly file, i.e. main.a51 in the Target 1> Source Group 1 folder then build the target will do? I'm very lost, pls help. Thanx. regards
Take a look to the project: C:\Keil\c51\Examples\A51 and to the file C:\Keil\C51\ASM\Template.A51
Hi, Thanx alot for the links. So... when i finish the coding and I build the Target, i got (0) Errors and (0) Warnings. But for BUILD, it only tells us whether is there any syntax error. And I can't find COMPILE in the uVision2 that I use. How can i check whether it perform as i wish? After building, i got Main.a51, Main.lts, Mian.obj, Project.hex, Project, Project.lnp, Project and Project.m51. thanx. regards
I think you should read the manual c:\keil\c51\hlp\gs51.chm.
even more important is "the bible" re assembler chapter 2 is MAMNDATORY. Erik here are the links to "the bible" Chapter 1 http://www.semiconductors.philips.com/acrobat/various/80C51_FAM_ARCH_1.pdf chapter 2 http://www.semiconductors.philips.com/acrobat/various/80C51_FAM_PROG_GUIDE_1.pdf chapter 3 http://www.semiconductors.philips.com/acrobat/various/80C51_FAM_HARDWARE_1.pdf
