Hi, I am using calloc in a function to allocate memory to my array. This function writes to the array different number of elements each time the function is called. Here is my problem. Say for the first time function writes to all the 3 locations and next time it writes to only first 2 locations. After the second call, the 3rd memory locations still contains the value written by the first function call. I understand that is the way it works.But I want to know if there is a way to erase all the locations before calling the function again? Is there any built-in function available? Also when I print the values of array initially it doesn't print zeroes. I have read that calloc initializes the memory fields to 0's. Following is the function code.
function write_to_array(int value) { int xdata *ascii_value,i; ascii_value = calloc(3, sizeof (int)); for(i=0;value!=0;i++) { mod = value%10; c = mod+'0'; ascii_value[i] = toascii(c); value/=10; } }
since 1987? I have not written even a single line for a PC, only for 'small embedded'. For that very reason, I have had no reason to look at the C standard since then.
This is exactly the sort of attitude that has resulted in the world being full of unmaintainable, non-portable code.
The 'C' standard applies to the 'C' language, not the platform.
I posted "A conforming freestanding implementation" still allow function pointers which, as i stated are "wrestled into an unsuited architecture"
Since you can not 'attack' that statement, instead you attack my 'attitude'
'portability' is arguable, but DO NOT accuse me of unmainatainable code, you have no foundation for that. Having the C standard in one hand while typing with the other is NOT a requirement for mainatainable code, au contraire, the least maintainable code I have seen has been written by people discussing whether code is "Real C".
Portable code for a uC you have got to be kidding. That is one of those absolute fallacies that keep coming up.
I guarantee you that my code is far more maintainable than much code I have seen that was littered with 'portability switches'. I can quote a statement I have made several times: "I do not give a hoot if code works, I care if it is maintainable". You can fix maintainable code that does not work, but get a bug report on unmaintanable code that 'works' and you are in deep Doo-Doo.
Were I to replace a '51 with e.g. an ARM the code (even if written by Jack Sprat) would by no description imaginable be 'portable'. Is it possible to 'port' such code, sure, but that you just load it into the other compiler because C code is portable is pure and unadulterated BULLSHIT when talking about microcontrollers.
There is so much going on in certain quarters to make a 'port' of something that 99.23% sure is never going to be 'ported' possible - what a wasted effort.
PS looking forward to seing what you can attack in this post :)
Speak for yourself. I write portable code.
I noticed a comment or two about portablilty and embedded systems. I've been doing embedded systems for 20 years, both in assembly and C. I can assure you that Portability in an embedded system is both important and desirable, but very difficult to obtain.
As an example, I have had to port the same program now from a silabs F320 to a F310 to an F342 and now to an F040.
Each of these required slightly different code, most of which was abstracted by the use of headers for the machine specific portions. The code however, still has processor dependant sections. I wrote the code in such a way, that the processor dependent sections (such as initialization, powerup, powerdown, and port I/O are contained in single simple modules.
The code is however highly dependent on the Silabs 8051 architecture. It specifically is based around the PCA array. porting to another 8051 with a PCA array would be pretty easy. Porting to another processor would not be to hard (basically 5 short routines and one long one (the PCA handler) would have to be re-written, but 80% of the code will work untouched (with the use of some judicial defines).
So portablilty needs to be cast in terms of same architecture vs different architecture. Portablitly is necessary and desirable if you are doing the same general CPU/arch.
I have to weigh in on the side of Dynamic allocation has no place in embedded system (especially 8051's), along with Java and the rest of the abortions that people try to cram into embedded systems.
As for the arguement about char, unsigned char and signed char, from the compiler point of view they are all distinct types. From the functional point of view they are vastly different.
I do a lot of communication protocols. Some are 8 bit binary, some are not. You learn really quickly to explicitly use unsigned vs signed. Just as an example, suppose you have an 8 bit data stream. you define something like
unsigned int cksum=0; char c; c=input_from_port(); cksum+=C;
vs unsigned int cksum=0; unsigned char c; c=input_from_port(); cksum+=C; and I guarantee you that you will get the wrong checksum in one of these cases, because the compiler will treat C as a signed addition, rather than an unsigned one.
Chars are defined in an 8 bit world to be 8 bits, but subsequent expressions may sign extend characters that are not explicitly defined as unsigned char .
Some compilers treat signed char and char as signed number, while others treat unsigned char and char as unsigned numbers.
Cheers
As an example, I have had to port the same program now from a silabs F320 to a F310 to an F342 and now to an F040. ... The code is however highly dependent on the Silabs 8051 architecture. the 040 is standard '51 architecture the f3x is "Silabs architecture" aka the deviates.
So portablilty needs to be cast in terms of same architecture vs different architecture. Portablitly is necessary and desirable if you are doing the same general CPU/arch. portability is a joke. There are so many differences between the various uCs that while 'reuse of code' is valid, 'portability' is not. I have seen code that needed an enormous helping of tomato sauce just because it had been written 'portable'
I have migrated code from one '51 processor to another and if anyone told me that I 'ported' the code, I would call him a liar. Did i reuse a lot of code? of course, but ported - no way. If I had 'ported' I would have lost the advantages the processor I changed to had over its predecessor. I have seen 'ported' code that bit-banged IIC on processors with HW IIC, is that in any way reasomable - absolutely not. When asked, the so called programmer answered "If I use the HW IIC it is not portablr" baloney, that is putting a premium on something unlikely (porting to a 'dumber' uC).
As for the arguement about char, unsigned char and signed char, from the compiler point of view they are all distinct types. From the functional point of view they are vastly different. I vote for outlawing 'char', the only legal should be unsigned and signed, and that has the GLORIOUS side effect of making it impossible to use most of the library routines that all, because they were developed for 'full size' machines, really do not have a place in a '51.
<amateurish code bodging nonsense snipped>
I vote for outlawing 'char', the only legal should be unsigned and signed...
Look, you've already demonstrated your poor knowledge of standard 'C' and refused to try and educate yourself by reading the one document that might help - the 'C' standard - so please, would you try and refrain from posting rubbish on the topic you know so little about?
standard 'C' ... so please, would you try and refrain from posting rubbish on the topic you know so little about?
There is NOTHING in my post about "standard C" I do not know why you bring that up. Only about "C and its application in small embedded". If you are a proponent of the stupid "C is C wherever it is applied" I feel sorry for you.
I do not have ANY 'char' 'int' 'short' or so in ANY of my code everything is either signed or unsigned.
If you have a beef with that post "my coding style is different" not some blabber about 'standard C'.
You keep referring to me as an 'amateur', I have written C for small embedded 15+ years and heve developed a host of methods for EFFICIENT C for small embedded not STUIPID "standard C for small embedded"
Good lord man, ignoring The Standard's distinction between 'plain' char, "signed char", and "unsigned char", why do you even bother with C at all? Profound ignorance (intolerance, indifference, etc.) of the language/standard is no excuse! Just do it in assembly language if that's the case. No questions asked or answered -- simple, done, no discussion, "Kirk out".
No. 'C' is defined by the ANSI standard, what you have written is something that looks a bit like 'C'.
If you were a professional we wouldn't be having this discussion in the first place.
Good lord man, ignoring The Standard's distinction between 'plain' char, "signed char", and "unsigned char", who said ANYTHING about "ignoring The Standard". The fact is that plain 'char' is ambigouous and in small embedded C is not needed. i had, some years ago, a problem with a compiler that was not consistent in which side of the ambiguity it leaned towards and the simple way to avoid ambiguity is to avoid what is ambighous.
what you have written is something that looks a bit like 'C'. so you adhere to the same mantra as the only guy I ever fired who said when told to make some code more efficient "then it will not be real C".
If you were a professional we wouldn't be having this discussion in the first place. correct if it is required to be a blabbering idiot (C is C wherevere it is used) to be considered a 'professional'.
It may be that you are a "professional in C", but based on your total refusal of acknowledging the facts of working in 'small embedded' you are definitely not a professional re C51
The Cidiots that insist on totally ignoring that using a small micro makes ther beloved 'C standard' too inclusive should go back to their beloved PC where everything the 'C standard' states may be proper practice.
Going by what you guys state you should require Keil to include fopen() etc in C51 since that is part of "the C standard". Or is it that YOU, not whichever user, is to decide what parts of the "C standard" apply to the '51 and C51
<usual incomprehensible rant snipped>
Oh dear, wrong again. Time you read the standard.
"who said ANYTHING about "ignoring The Standard"
Nobody did. You left off the "'s distinction ...". Quoting the original complaint:
"... ignoring The Standard's distinction between 'plain' char, "signed char", and "unsigned char", ... "
The point (I think) is that there are three char types, all equally valid in small embedded C, but you have to understand the distinction between the three types and use them appropriately, regardless whether the target is "small embedded" or not.
"The fact is that plain 'char' is ambigouous and in small embedded C is not needed."
'Plain' char also has its place in "small embedded" systems.
Excerpts from The Standard's section 6.2.5 paragraphs 3-6 making the distinction between the three char types:
(3) "An object declared as type char is large enough to store any member of the basic execution character set. If a member of the basic execution character set is stored in a char object, its value is guaranteed to be nonnegative. If any other character is stored in a char object, the resulting value is implementation-defined but shall be within the range of values that can be represented in that type."
(4) "There are five standard signed integer types, designated as signed char, short int, int, long int, and long long int. ..."
(5) "An object declared as type signed char occupies the same amount of storage as a 'plain' char object. ..."
(6) "For each of the signed integer types, there is a corresponding (but different) unsigned integer type (designated with the keyword unsigned) that uses the same amount of storage (including sign information) and has the same alignment requirements. ..."
From those excerpts, we see that 'plain' char is intended for values from the basic execution character set, that those values are nonnegative, and storing any other value is implementation-defined (i.e., your implementation disambiguates it). So, simply put, for small embedded systems that deal with text-y things (e.g., an LCD message), 'plain' char is a perfectly valid, innocuous, and useful type.
From those excerpts, we also see that there are two char-sized integer types, "signed char" and "unsigned char", to be used when one wants to use an integer type other than the signed and unsigned varieties of short, int, long, and long long. These second and third char types, just like 'plain' char are useful and have their place in systems, "small embedded" or otherwise.
Don't use 'plain' char when you want do to signed integer arithmetic on char-sized objects; use signed char.
Don't use 'plain' char when you want do to unsigned integer arithmetic on char-sized objects; use unsigned char.
Do use 'plain' char when you are dealing with character set functionality.
"Going by what you guys state you should require Keil to include fopen() etc in C51 since that is part of "the C standard"."
Who guys? We already discussed above that fopen() wouldn't be required in a freestanding implementation.
Do use 'plain' char when you are dealing with character set functionality Please give me an example of "character set functionality" ONLY for a char in small embedded. Since small embedded rarely (never?) have a character e.g. ASCII on which no arithmetic is performed, using 'just' char there makes the ambiguity shine through.
Please give me an example of where you need to use 'just' char in a small embedded system. Please do not suggest to use the libraries which, since specified for 'full size', are way too 'comprehensive' and thus too large for small embedded.
DO NOTE, my suggestion 'outlaw char' was in relation to 'portability' (which I do not think apply to small embedded) but in reuse of code (which I do think apply to small embedded) the ambiguity may bite you.
what we are discussing is not 'C' but design philosophy.
I have yet to find two persons that can agree fully in that area.
My philiosophy is 'efficiency' (whatever the cost) and I gather that your philiosophy is 'purity' (whatever the cost).
so you take the high road and I take the low road but I'll be in Scotland before ye (i.e. faster code)
