free professional TCP/IP stack and dev system
from
http://www.cygnal.org/ubb/Forum1/HTML/001343.html
The Embedded Ethernet Development kit has just been released. The kit includes an 'F12x Target Board, AB2 Ethernet Development Board, and has a TCP/IP Configuration wizard that generates CMX TCP/IP object code and the framework code needed to execute the stack. The CMX TCP/IP Stack is included free of charge or royalties.
If you already have an 'F12x Target Board and an AB2, the TCP/IP Configuration Wizard can be downloaded from TCP/IP Config Wizard Web Page .
Using the wizard, you can have a web server up and running in less than 10 minutes. The configuration wizard generates 100% of the required code to get a basic web server up and running.
